ONTAP EMS reference
lifp.net events
lifp.net EMS events occur while assigning network ports to broadcast domains, when LIF Placement subnet discovery finds a port that is assigned to a broadcast domain that is different from the broadcast domain to which other ports in the same physical broadcast domain are assigned.
lifp.net.bdmismatch
Severity
ERROR
This message occurs while assigning network ports to broadcast domains, when LIF Placement subnet discovery finds a port that is assigned to a broadcast domain that is different from the broadcast domain to which other ports in the same physical broadcast domain are assigned.
Corrective Action
Ports assigned to broadcast-domains need to be corrected by the admin. The ports in one physical broadcast domain must be assigned to a single broadcast-domain.
Syslog Message
In IPspace %s, other ports in the same physical broadcast domain are assigned to broadcast-domain %s but %s is assigned to broadcast-domain %s.
ipspacename (STRING): IPspace name.
broadcastdomainOnOtherPorts (STRING): Broadcast-domain name.
port (STRING): Port name.
broadcastdomainOnCurrentPort (STRING): Broadcast-domain name.
