ONTAP EMS reference
lun.vol events
LUN.vol.no.space
Severity
ERROR
This message occurs when an operation on a LUN or NVMe namespace fails due to insufficient space in the volume.
Corrective Action
Add space to the volume and retry the operation.
Syslog Message
An operation on %s in volume %s (DSID %llu) failed due to lack of space in the volume.
lun_path (STRING): Path for the LUN or NVMe namespace.
volume_name (STRING): Name of the containing volume.
volume_dsid (LONGINT): Data Set ID (DSID) of the containing volume.
LUN.vol.proc.fail.no.space
Severity
ERROR
This message occurs when the processing for LUNs in the volume has failed due to lack of space in the volume or containing aggregate.
Corrective Action
Check accompanying event messages to determine whether the volume or containing aggregate lacks space. Add space to the volume or aggregate containing the volume as necessary before retrying the operation. If the volume was being transitioned, issue the command 'lun transition start' to retry; otherwise issue the command 'lun rescan -sync' to complete processing of LUNs in the volume.
Syslog Message
Processing for LUNs in volume %s (DSID %llu) failed due to lack of space.
volume_name (STRING): Name of the volume for which the processing failed.
volume_dsid (LONGINT): Data Set ID (DSID) of the volume for which the processing failed.
