mlm.arr events
mlm.arr.affinity.not.queued
Severity
NOTICE
This message occurs when the current processing of an error event prevents the Asymmetric Logical Unit Access (ALUA) handler from queuing an affinity switch event.
Corrective Action
(None).
Syslog Message
Affinity event %s not queued for LUN %s.
event (STRING): Affinity event for asymmetric array.
serialno (STRING): Serial number of the array LUN.
mlm.arr.many.affinity.error
Severity
ERROR
This message occurs when the Asymmetric Logical Unit Access (ALUA) handler encounters too many affinity errors, which might lead to reduced I/O throughput.
Corrective Action
Evaluate the back-end array connectivity for optimal LUN balance across array controllers. Also check for failures reported by the back-end array with regards to ALUA target port group settings. Verify that FlexArray connectivity is done as per best-practice guide.
Syslog Message
Failing cmd %s for LUN %s due to too many affinity errors.
cdb (STRING): String containing the opcode byte of the command descriptor block (CDB) that was sent to the device.
