mlm.arr events
mlm.arr.affinity.not.queued
- Severity
NOTICE
 - Description
This message occurs when the current processing of an error event prevents the Asymmetric Logical Unit Access (ALUA) handler from queuing an affinity switch event.
 - Corrective Action
(None).
 - Syslog Message
Affinity event %s not queued for LUN %s.
 - Parameters
event (STRING): Affinity event for asymmetric array.
serialno (STRING): Serial number of the array LUN.
mlm.arr.many.affinity.error
- Severity
ERROR
 - Description
This message occurs when the Asymmetric Logical Unit Access (ALUA) handler encounters too many affinity errors, which might lead to reduced I/O throughput.
 - Corrective Action
Evaluate the back-end array connectivity for optimal LUN balance across array controllers. Also check for failures reported by the back-end array with regards to ALUA target port group settings. Verify that FlexArray connectivity is done as per best-practice guide.
 - Syslog Message
Failing cmd %s for LUN %s due to too many affinity errors.
 - Parameters
cdb (STRING): String containing the opcode byte of the command descriptor block (CDB) that was sent to the device.
