monitor.rtcwarnlowpower events
Creating your file...
Your file is ready
monitor.rtcWarnLowPower
- Severity
ERROR
- Description
This message occurs when the real-time clock (RTC) battery is at a "warning low" voltage level.
- Corrective Action
Correct any environmental problems, such as chassis over- temperature. If the real-time clock battery voltage is still below normal 60 minutes after environmental problems have been corrected, replace it at the next available maintenance window.
- Syslog Message
Real-time clock battery voltage is below normal (%s).
- Parameters
reading (STRING): Battery voltage reading (mV).
