netgroup.nis events
Creating your file...
netgroup.nis.byhost.decode
- Severity
ERROR
- Description
This message occurs when the netgroup.byhost remote procedure call to the Network Information Service (NIS) server returns a response that cannot be decoded.
- Corrective Action
Check the netgroup byhost database on the NIS server for lines that have more than 1024 characters.
- Syslog Message
NIS server returned an undecodable response for Vserver "%s" during lookup for netgroup "%s".
- Parameters
vserver (STRING): Name of the Vserver on which the problem is occurring.
netgroup (STRING): Name of the netgroup for the lookup request.
netgroup.nis.byhost.missing
- Severity
INFORMATIONAL
- Description
This message occurs when the netgroup.byhost map is not configured on the Network Information Service (NIS) server and NIS is configured as a ns-switch source for the Vserver. Enabling netgroup.byhost enables mount operations to succeed faster when the netgroup size is large.
- Corrective Action
Consider configuring the netgroup.byhost map on the NIS server to gain better performance with netgroups.
- Syslog Message
NIS server missing netgroup.byhost map for Vserver "%s" during lookup for netgroup "%s".
- Parameters
netgroup.nis.config
- Severity
ERROR
- Description
This message occurs when a netgroup lookup request finds that Network Information Service (NIS) is specified as a ns-switch source, but NIS is not configured for the Vserver. Netgroup lookups using NIS will not function.
- Corrective Action
Check the ns-switch sources configured for the netgroup database using "vserver services name-service ns-switch show" and the NIS configuration for the Vserver using "nis-domain show". Either remove NIS as a ns-switch source, or configure NIS.
- Syslog Message
NIS configuration issues found for Vserver "%s" during lookup for netgroup "%s".
- Parameters
