ONTAP EMS reference
netgroup.nis events
netgroup.nis.byhost.decode
Severity
ERROR
This message occurs when the netgroup.byhost remote procedure call to the Network Information Service (NIS) server returns a response that cannot be decoded.
Corrective Action
Check the netgroup byhost database on the NIS server for lines that have more than 1024 characters.
Syslog Message
NIS server returned an undecodable response for Vserver "%s" during lookup for netgroup "%s".
vserver (STRING): Name of the Vserver on which the problem is occurring.
netgroup (STRING): Name of the netgroup for the lookup request.
netgroup.nis.byhost.missing
Severity
INFORMATIONAL
This message occurs when the netgroup.byhost map is not configured on the Network Information Service (NIS) server and NIS is configured as a ns-switch source for the Vserver. Enabling netgroup.byhost enables mount operations to succeed faster when the netgroup size is large.
Corrective Action
Consider configuring the netgroup.byhost map on the NIS server to gain better performance with netgroups.
Syslog Message
NIS server missing netgroup.byhost map for Vserver "%s" during lookup for netgroup "%s".
netgroup.nis.config
Severity
ERROR
This message occurs when a netgroup lookup request finds that Network Information Service (NIS) is specified as a ns-switch source, but NIS is not configured for the Vserver. Netgroup lookups using NIS will not function.
Corrective Action
Check the ns-switch sources configured for the netgroup database using "vserver services name-service ns-switch show" and the NIS configuration for the Vserver using "nis-domain show". Either remove NIS as a ns-switch source, or configure NIS.
Syslog Message
NIS configuration issues found for Vserver "%s" during lookup for netgroup "%s".
