netif.tcp events
netif.tcp.conn.bad.checksum
Severity
ERROR
This message occurs when a bad checksum is detected in the incoming TCP packets.
Corrective Action
If experiencing network issues, corrupted TCP packets might be an issue. Check the network components along the path of TCP connection.
Syslog Message
TCP packet with bad checksum detected on port %s. The packet arrived on connection with source address %s and destination_address %s.
local_port (STRING): Ethernet port where the TCP bad checksum packets were detected.
source_address (STRING): Source IP address of the connection.
destination_address (STRING): Destination IP address of the connection.
