      netif.tcp events
netif.tcp.conn.bad.checksum
- Severity
ERROR
 - Description
This message occurs when a bad checksum is detected in the incoming TCP packets.
 - Corrective Action
If experiencing network issues, corrupted TCP packets might be an issue. Check the network components along the path of TCP connection.
 - Syslog Message
TCP packet with bad checksum detected on port %s. The packet arrived on connection with source address %s and destination_address %s.
 - Parameters
local_port (STRING): Ethernet port where the TCP bad checksum packets were detected.
source_address (STRING): Source IP address of the connection.
destination_address (STRING): Destination IP address of the connection.
