qos.mgmt events
Creating your file...
Your file is ready
qos.mgmt.operation.failed
- Severity
ERROR
- Description
This message indicates that cluster quality of service (QoS) cannot propagate settings to the classification and control components on the specified node. This might be a transient condition, or it might indicate insufficient resources to complete the operation. QoS workload classification and control might behave incorrectly on this node.
- Corrective Action
Inspect the management gateway process log for errors indicating why the command failed. If this behavior persists, contact NetApp technical support.
- Syslog Message
QoS configuration update failed on node %s: %s
- Parameters
node (STRING): Node on which operation failed.
error (STRING): Error description.
