ONTAP EMS reference
qos.mgmt events
qos.mgmt.operation.failed
Severity
ERROR
This message indicates that cluster quality of service (QoS) cannot propagate settings to the classification and control components on the specified node. This might be a transient condition, or it might indicate insufficient resources to complete the operation. QoS workload classification and control might behave incorrectly on this node.
Corrective Action
Inspect the management gateway process log for errors indicating why the command failed. If this behavior persists, contact NetApp technical support.
Syslog Message
QoS configuration update failed on node %s: %s
node (STRING): Node on which operation failed.
error (STRING): Error description.
