qos.min events
qos.min.tput.not.honoured.for.sync
Severity
NOTICE
This message occurs when minimum throughput value is not honoured if adaptive QoS is set on a SnapMirror Synchronous protected storage object.
Corrective Action
(None).
Syslog Message
Adaptive QoS policy "%s" set on SnapMirror Synchronous volume "%s" or any of it's storage object has a min-throughput value set. SnapMirror Synchronous does not support min-throughput hence min-throughput setting will not be honoured from the policy, only max-throughput setting will be honoured.
policy (STRING): Policy group name.
volume (STRING): Volume name.
