qos.min events
qos.min EMS events occur when minimum throughput value is not honoured if adaptive QoS is set on a SnapMirror Synchronous protected storage object.
qos.min.tput.not.honoured.for.sync
- Severity
NOTICE
- Description
This message occurs when minimum throughput value is not honoured if adaptive QoS is set on a SnapMirror Synchronous protected storage object.
- Corrective Action
(None).
- Syslog Message
Adaptive QoS policy "%s" set on SnapMirror Synchronous volume "%s" or any of it's storage object has a min-throughput value set. SnapMirror Synchronous does not support min-throughput hence min-throughput setting will not be honoured from the policy, only max-throughput setting will be honoured.
- Parameters
policy (STRING): Policy group name.
volume (STRING): Volume name.
