repository.dangling events
Creating your file...
Repository.Dangling.Data.File
- Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
- Severity
ERROR
- Description
This message occurs during a client file operation request, when the Infinite Volume namespace redirector runs into failures that prevent it from cleaning up a file on a data constituent. This dangling file is unnecessarily consuming resources.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
Failures caused the Infinite Volume namespace redirector to leave a dangling file (handle: %s) on a data constituent in Vserver %u.
- Parameters
filehandle (STRING): File handle of the file that is left dangling in the data constituent.
vserverId (INT): Vserver ID for which the error occurred.
Repository.Dangling.Redirector
- Deprecated
- Severity
ERROR
- Description
This message occurs during a client file operation request, when the Infinite Volume namespace redirector runs into a dangling redirector file on the namespace constituent.
- Corrective Action
- Syslog Message
Failures caused the Infinite Volume namespace redirector to leave a dangling redirector file %s on the namespace constituent in Vserver %u.
- Parameters
filehandle (STRING): File handle of the redirector file that is left dangling in the namespace constituent.
