ONTAP EMS reference
repository.dangling events
repository.dangling EMS events occur when ONTAP encounters issues associated with Infinite Volume namespace redirector cleanup failures.
Repository.Dangling.Data.File
Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
Severity
ERROR
This message occurs during a client file operation request, when the Infinite Volume namespace redirector runs into failures that prevent it from cleaning up a file on a data constituent. This dangling file is unnecessarily consuming resources.
Corrective Action
Contact NetApp technical support.
Syslog Message
Failures caused the Infinite Volume namespace redirector to leave a dangling file (handle: %s) on a data constituent in Vserver %u.
filehandle (STRING): File handle of the file that is left dangling in the data constituent.
vserverId (INT): Vserver ID for which the error occurred.
Repository.Dangling.Redirector
Deprecated
Severity
ERROR
This message occurs during a client file operation request, when the Infinite Volume namespace redirector runs into a dangling redirector file on the namespace constituent.
Corrective Action
Syslog Message
Failures caused the Infinite Volume namespace redirector to leave a dangling redirector file %s on the namespace constituent in Vserver %u.
filehandle (STRING): File handle of the redirector file that is left dangling in the namespace constituent.
