sas.unsupported events
sas.unsupported.port
Severity
ALERT
This message occurs when ONTAP detects that a cable is attached to an I/O module port that is permanently disabled and does not support attachment.
Corrective Action
Remove the cable from the unsupported port on the I/O module.
Syslog Message
Port 0b2 on shelf ID %lld.%s, cable detected on unsupported port.
shelfID (LONGINT): Shelf ID of the shelf reporting the error.
element (STRING): I/O module designator (A or B).
