sas.unsupported events
sas.unsupported EMS events occur when ONTAP detects that a cable is attached to an I/O module port that is permanently disabled and does not support attachment.
sas.unsupported.port
- Severity
ALERT
- Description
This message occurs when ONTAP detects that a cable is attached to an I/O module port that is permanently disabled and does not support attachment.
- Corrective Action
Remove the cable from the unsupported port on the I/O module.
- Syslog Message
Port 0b2 on shelf ID %lld.%s, cable detected on unsupported port.
- Parameters
shelfID (LONGINT): Shelf ID of the shelf reporting the error.
element (STRING): I/O module designator (A or B).
