secd.dc events
Creating your file...
secd.dc.out.of.pipe.instances
- Severity
ALERT
- Description
This message occurs when the Windows Domain Controller (DC), while responding to an MSRPC request from Data ONTAP®, returns an error indicating that it ran out of pipe instances in the listening state. This can happen when the requests from Data ONTAP are received by the DC during a timing window when the limited number of listening pipe instance are already allocated to other requests. Such errors received by Data ONTAP might result in longer CIFS/NFS authentication and/or access times, potentially resulting in CIFS/NFS client timeouts.
- Corrective Action
Contact Microsoft support.
- Syslog Message
MSRPC for Vserver %s to %s:%s was retried %d times (delay: %d usecs).
- Parameters
vserver (STRING): Vserver that encountered the failure.
dc (STRING): DC that returned the error.
pipe (STRING): Pipe on the DC.
retries (INT): Number of retries.
delay (INT): Time (usecs) spent retrying.
