sfo.arl events
Creating your file...
sfo.arl.gb.failed.conversion
- Severity
ERROR
- Description
This message occurs when ARL/giveback of the Storage Failover (SFO) aggregate fails because of active volume conversion operations against one or more volumes on this aggregate while acquiring the RAID lock.
- Corrective Action
When volume conversion is complete, re-run the command 'storage failover takeover/giveback'.
- Syslog Message
%s %s.
- Parameters
msg (STRING): Error that prevented ARL/GB.
aggr (STRING): Name of the aggregate that was not TO/GB.
sfo.arl.notAllowed
- Severity
NOTICE
- Description
This message occurs when a requested Storage Failover (SFO) aggregate relocation operation is refused because the destination node is not the high-availability (HA) partner of the source node.
- Corrective Action
Verify that the destination node of the aggregate relocation is the source node's high-availability (HA) partner by using the "storage failover show" command. Retry the aggregate relocation with the correct source and destination node.
- Syslog Message
SFO aggregate relocation refused for aggregate %s because the destination is not an HA partner. Source node: %s (NVRAM ID: %llu), destination node: %s (NVRAM ID: %llu).
- Parameters
aggr_name (STRING): Name of the aggregate.
src_name (STRING): Name of the source node.
src_nvram_id (LONGINT): NVRAM ID of the source node.
dest_name (STRING): Name of the destination node.
dest_nvram_id (LONGINT): NVRAM ID of the destination node.
sfo.arl.recvdBadSignal
- Severity
INFORMATIONAL
- Description
This message occurs when the aggregate relocation worker thread receives an unexpected signal from the kernel subsystem.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
signal_info (STRING): Additional information on the signal received, indicating if it was a bad message type or a bad signal mask.
signal_value (INT): Value of the unexpected signal.
