ONTAP EMS reference
sfo.arl events
sfo.arl EMS events occur when ONTAP encounters issues associated with storage failover (SFO) aggregate relocation operations.
sfo.arl.gb.failed.conversion
Severity
ERROR
This message occurs when ARL/giveback of the Storage Failover (SFO) aggregate fails because of active volume conversion operations against one or more volumes on this aggregate while acquiring the RAID lock.
Corrective Action
When volume conversion is complete, re-run the command 'storage failover takeover/giveback'.
Syslog Message
%s %s.
msg (STRING): Error that prevented ARL/GB.
aggr (STRING): Name of the aggregate that was not TO/GB.
sfo.arl.notAllowed
Severity
NOTICE
This message occurs when a requested Storage Failover (SFO) aggregate relocation operation is refused because the destination node is not the high-availability (HA) partner of the source node.
Corrective Action
Verify that the destination node of the aggregate relocation is the source node's high-availability (HA) partner by using the "storage failover show" command. Retry the aggregate relocation with the correct source and destination node.
Syslog Message
SFO aggregate relocation refused for aggregate %s because the destination is not an HA partner. Source node: %s (NVRAM ID: %llu), destination node: %s (NVRAM ID: %llu).
aggr_name (STRING): Name of the aggregate.
src_name (STRING): Name of the source node.
src_nvram_id (LONGINT): NVRAM ID of the source node.
dest_name (STRING): Name of the destination node.
dest_nvram_id (LONGINT): NVRAM ID of the destination node.
sfo.arl.recvdBadSignal
Severity
INFORMATIONAL
This message occurs when the aggregate relocation worker thread receives an unexpected signal from the kernel subsystem.
Corrective Action
(None).
Syslog Message
(None).
signal_info (STRING): Additional information on the signal received, indicating if it was a bad message type or a bad signal mask.
signal_value (INT): Value of the unexpected signal.
