token.vol events
Creating your file...
token.vol.cache.cleared
- Severity
NOTICE
- Description
This message occurs when a 'volume offline' operation results in clearing the token cache for that volume.
- Corrective Action
(None).
- Syslog Message
Token cache for volume %s was cleared because the volume went offline.
- Parameters
volume_name (STRING): Name of the volume whose token cache was cleared.
token.vol.is.compressed
- Severity
NOTICE
- Description
This message occurs when a 'token create' request fails because the container is a compressed volume.
- Corrective Action
(None).
- Syslog Message
A 'token create' request in volume %s failed because the volume is compressed.
- Parameters
volume_name (STRING): Name of the volume for which the 'token create' request failed.
token.vol.is.sparse
- Severity
NOTICE
- Description
This message occurs when a 'token create' request fails because the container is a sparse volume.
- Corrective Action
(None).
- Syslog Message
A 'token create' request in volume %s failed because the volume is sparse.
- Parameters
token.vol.max.count.reached
- Severity
NOTICE
- Description
This message occurs when the maximum number of tokens per volume is reached. Tokens cannot be created in the volume unless some existing tokens expire.
- Corrective Action
(None).
- Syslog Message
Tokens cannot be created in volume %s because the maximum number of tokens per volume has been reached.
- Parameters
volume_name (STRING): Name of the volume in which the maximum number of tokens has been reached.
