ONTAP EMS reference
token.vol events
token.vol EMS events occur when ONTAP encounters issues associated with volume-level token operations.
token.vol.cache.cleared
Severity
NOTICE
This message occurs when a 'volume offline' operation results in clearing the token cache for that volume.
Corrective Action
(None).
Syslog Message
Token cache for volume %s was cleared because the volume went offline.
volume_name (STRING): Name of the volume whose token cache was cleared.
token.vol.is.compressed
Severity
NOTICE
This message occurs when a 'token create' request fails because the container is a compressed volume.
Corrective Action
(None).
Syslog Message
A 'token create' request in volume %s failed because the volume is compressed.
volume_name (STRING): Name of the volume for which the 'token create' request failed.
token.vol.is.sparse
Severity
NOTICE
This message occurs when a 'token create' request fails because the container is a sparse volume.
Corrective Action
(None).
Syslog Message
A 'token create' request in volume %s failed because the volume is sparse.
token.vol.max.count.reached
Severity
NOTICE
This message occurs when the maximum number of tokens per volume is reached. Tokens cannot be created in the volume unless some existing tokens expire.
Corrective Action
(None).
Syslog Message
Tokens cannot be created in volume %s because the maximum number of tokens per volume has been reached.
volume_name (STRING): Name of the volume in which the maximum number of tokens has been reached.
