wafl.ntfsunixsecurityops events
Creating your file...
wafl.ntfsUnixSecurityOps
- Severity
NOTICE
- Description
This message occurs when a UNIX-type permissions or ownership change is attempted by an NFS client on an NTFS (Windows) volume, but changes of this type are prohibited by an export policy rule.
- Corrective Action
Use the "vserver show -fields uuid" command to find the Vserver name corresponding to the Vserver's UUID. Use the "volume file show-inode" command with the file ID and volume name information to find the file or directory path and consider using Windows client to set file or directory attributes.
- Syslog Message
NFS client attempted prohibited change of UNIX permissions for file ID: %d, on NTFS volume : %s%s%s
- Parameters
fileid (INT): File ID of the entry in the directory.
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): Vserver's Universal Unique Identifier (UUID).
