wafl.quota events
wafl.quota.control.inconsistent
- Severity
ERROR
- Description
This message occurs when the quota control file is inconsistent, or when it is consistent but the qtree metatdata file refers to a vFiler(tm) unit that no longer exists.
- Corrective Action
Reinitialize quotas for the volume.
- Syslog Message
Quota: /vol/%s%s%s or a quota tree on it referred to a nonexistent vFiler unit. Quota: Quotas have been turned off.
- Parameters
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
wafl.quota.control.invalid
- Severity
ERROR
- Description
This message occurs when the system discovers that an invalid quota control file exists.
- Corrective Action
- Syslog Message
Quota: Invalid quota control file on %s %s%s%s%s. Quota: Quotas have been turned off.
- Parameters
type (STRING): Type of object (volume or aggregate).
owner (STRING): Volume owner.
wafl.quota.db.createFail
- Severity
NOTICE
- Description
This message occurs when the system cannot create the quota database file.
- Corrective Action
(None).
- Syslog Message
Quota: Could not create the quota database on %s %s%s%s%s (volume might be full).
- Parameters
wafl.quota.db.missing
- Severity
ERROR
- Description
This message occurs when the system is unable to locate a quota usage database.
- Corrective Action
- Syslog Message
WAFL: No quota usage database on %s %s%s%s%s.
- Parameters
wafl.quota.db.noMemory
- Severity
ERROR
- Description
This message occurs when the system cannot allocate the quota usage database during initialization.
- Corrective Action
Add more memory or upgrade the hardware.
- Syslog Message
WAFL: Could not obtain memory during load of quota usage database. The quota system was not started on %s %s%s%s%s.
- Parameters
wafl.quota.db.scanFailed
- Severity
ERROR
- Description
This event is issued when the system tries and fails to start the scanner necessary to complete a "quota on" command.
- Corrective Action
Quota initialization has failed due to lack of resources. Re-running a "quota on" after some time should solve the problem.
- Syslog Message
wafl: quota initialization could not be started on %s %s%s%s%s due to lack of resources. Please wait and re-run "quota on".
- Parameters
type (STRING): The type of object (volume/aggregate)
owner (STRING): The volume owner
vol (STRING): The volume name
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
wafl.quota.group.exceeded
- Severity
NOTICE
- Description
This event is issued when a group quota has been exceeded on a volume. This event will not be repeated for this group for a set time for until a 'quota resize' is performed. The amount of time is set by the 'quota logmsg' command.
- Corrective Action
Reduce usage by members of this group on this volume or increase the quota and run 'quota resize'.
- Syslog Message
gid %d: disk quota exceeded on volume %s%s%s%s. Additional warnings will be suppressed for approximately %d minutes or until a 'quota resize' is performed.
- Parameters
id (INT): The group identifier
mins (INT): Number of minutes warnings will be supressed
wafl.quota.groupQtree.correct
- Severity
NOTICE
- Description
This message occurs when a group quota has been corrected.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
id (INT): Group identifier.
tid (INT): Qtree identifier.
volident (STRING): Unique identifier for the volume in cases in which the volume name alone is insufficient.
vfwarn (STRING): vFiler warning suffix.
wafl.quota.groupQtree.exceeded
- Severity
NOTICE
- Description
This event is issued when a group quota has been exceeded on a tree. This event will not be repeated for this group and tree for a set time or until a 'quota resize' is performed. The amount of time is set by the 'quota logmsg' command.
- Corrective Action
Reduce usage by members of this group in this tree or increase the quota and run 'quota resize'.
- Syslog Message
gid %d tid %d: disk quota exceeded on volume %s%s%s%s. Additional warnings will be suppressed for approximately %d minutes or until a 'quota resize' is performed.
- Parameters
tid (INT): The tree identifier
wafl.quota.names.createFail
- Severity
NOTICE
- Description
This message occurs when the system cannot create the quota names file.
- Corrective Action
(None).
- Syslog Message
quota: Could not create new quota names file on %s %s%s%s%s.
- Parameters
wafl.quota.ntfs.defaultAclFail
- Severity
NOTICE
- Description
This message indicates that the system was unable to set the default ACL on an NTFS volume.
- Corrective Action
Set the security style to NTFS again or re-create the volume.
- Syslog Message
Unable to set default ACL on NTFS %s %s%s%s%s.
- Parameters
type (STRING): Type of object (volume/aggregate).
volident (STRING): Unique identifier of the volume when the volume name by itself is insufficient.
wafl.quota.off.vol.fail
- Severity
ERROR
- Description
This message occurs when the system could not turn off quotas on the volume.
- Corrective Action
Use the 'quota off' command to turn off quotas on the volume.
- Syslog Message
Quotas could not be turned off on volume %s%s.
- Parameters
owner (STRING): Owner of the volume
vol (STRING): Name of the volume
wafl.quota.qtree.correct
- Severity
NOTICE
- Description
This message occurs when a tree quota has been corrected.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
wafl.quota.qtree.exceeded
- Severity
NOTICE
- Description
This event is issued when a tree quota has been exceeded on a volume. This event will not be repeated for this tree for a set amount of time or until a 'quota resize' is performed. The amount of time is set by the 'quota logmsg' command.
- Corrective Action
Reduce usage in this tree or increase the quota and run 'quota resize'.
- Syslog Message
tid %d: tree quota exceeded on %s %s%s%s%s. Additional warnings will be suppressed for approximately %d minutes or until a 'quota resize' is performed.
- Parameters
mins (INT): Number of minutes warnings will be suppressed
object_uuid (STRING): Volume instance UUID of the resource object.
wafl.quota.sec.change
- Severity
INFORMATIONAL
- Description
This message indicates that the security style for a directory has been changed.
- Corrective Action
(None).
- Syslog Message
security style for /vol/%s%s%s/%s changed from %s to %s
- Parameters
dir (STRING): Directory name.
ostyle (STRING): Former security style.
nstyle (STRING): New security style.
wafl.quota.user.exceeded
- Severity
NOTICE
- Description
This event is issued when a user quota has been exceeded on a volume. This event will not be repeated for this user and volume for a set time or until a 'quota resize' is performed. The amount of time is set by the 'quota logmsg' command.
- Corrective Action
Reduce usage by this user on this volume or increase the quota and run 'quota resize'.
- Syslog Message
uid %d: disk quota exceeded on volume %s%s%s%s. Additional warnings will be suppressed for approximately %d minutes or until a 'quota resize' is performed.
- Parameters
id (INT): The user identifier
wafl.quota.user.exceeded.win
- Severity
NOTICE
- Description
- Corrective Action
- Syslog Message
disk quota exceeded on volume %s%s%s%s for Windows user ID: %s. Additional warnings will be suppressed for approximately %d minutes or until a 'quota resize' is performed.
- Parameters
id (STRING): Windows user identifier
wafl.quota.userQtree.correct
- Severity
NOTICE
- Description
This message occurs when a user quota has been corrected.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
id (INT): User identifier.
wafl.quota.userQtree.correct.win
- Severity
NOTICE
- Description
This message occurs when a user quota has been corrected and the user ID is a SID.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
id (STRING): Windows identifier value.
wafl.quota.userQtree.exceeded
- Severity
NOTICE
- Description
This event is issued when a user quota has been exceeded on a tree. This event will not be repeated for this user and tree for a set time or until a 'quota resize' is performed. The amount of time is set by the 'quota logmsg' command.
- Corrective Action
Reduce usage by this user in this tree or increase the quota and run 'quota resize'.
- Syslog Message
uid %d tid %d: disk quota exceeded on volume %s%s%s%s. Additional warnings will be suppressed for approximately %d minutes or until a 'quota resize' is performed.
- Parameters
wafl.quota.userQtree.exceeded.win
- Severity
NOTICE
- Description
- Corrective Action
- Syslog Message
tid %d: disk quota exceeded on volume %s%s%s%s for Windows user ID: %s. Additional warnings will be suppressed for approximately %d minutes or until a 'quota resize' is performed.
- Parameters
