ONTAP EMS reference
wafl.quota events
wafl.quota EMS events occur when ONTAP encounters issues associated with quota database management and quota limits.
wafl.quota.control.inconsistent
Severity
ERROR
This message occurs when the quota control file is inconsistent, or when it is consistent but the qtree metatdata file refers to a vFiler(tm) unit that no longer exists.
Corrective Action
Reinitialize quotas for the volume.
Syslog Message
Quota: /vol/%s%s%s or a quota tree on it referred to a nonexistent vFiler unit. Quota: Quotas have been turned off.
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
wafl.quota.control.invalid
Severity
ERROR
This message occurs when the system discovers that an invalid quota control file exists.
Corrective Action
Syslog Message
Quota: Invalid quota control file on %s %s%s%s%s. Quota: Quotas have been turned off.
type (STRING): Type of object (volume or aggregate).
owner (STRING): Volume owner.
wafl.quota.db.createFail
Severity
NOTICE
This message occurs when the system cannot create the quota database file.
Corrective Action
(None).
Syslog Message
Quota: Could not create the quota database on %s %s%s%s%s (volume might be full).
wafl.quota.db.missing
Severity
ERROR
This message occurs when the system is unable to locate a quota usage database.
Corrective Action
Syslog Message
WAFL: No quota usage database on %s %s%s%s%s.
wafl.quota.db.noMemory
Severity
ERROR
This message occurs when the system cannot allocate the quota usage database during initialization.
Corrective Action
Add more memory or upgrade the hardware.
Syslog Message
WAFL: Could not obtain memory during load of quota usage database. The quota system was not started on %s %s%s%s%s.
wafl.quota.db.scanFailed
Severity
ERROR
This event is issued when the system tries and fails to start the scanner necessary to complete a "quota on" command.
Corrective Action
Quota initialization has failed due to lack of resources. Re-running a "quota on" after some time should solve the problem.
Syslog Message
wafl: quota initialization could not be started on %s %s%s%s%s due to lack of resources. Please wait and re-run "quota on".
type (STRING): The type of object (volume/aggregate)
owner (STRING): The volume owner
vol (STRING): The volume name
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
wafl.quota.group.exceeded
Severity
NOTICE
This event is issued when a group quota has been exceeded on a volume. This event will not be repeated for this group for a set time for until a 'quota resize' is performed. The amount of time is set by the 'quota logmsg' command.
Corrective Action
Reduce usage by members of this group on this volume or increase the quota and run 'quota resize'.
Syslog Message
gid %d: disk quota exceeded on volume %s%s%s%s. Additional warnings will be suppressed for approximately %d minutes or until a 'quota resize' is performed.
id (INT): The group identifier
mins (INT): Number of minutes warnings will be supressed
wafl.quota.groupQtree.correct
Severity
NOTICE
This message occurs when a group quota has been corrected.
Corrective Action
(None).
Syslog Message
(None).
id (INT): Group identifier.
tid (INT): Qtree identifier.
volident (STRING): Unique identifier for the volume in cases in which the volume name alone is insufficient.
vfwarn (STRING): vFiler warning suffix.
wafl.quota.groupQtree.exceeded
Severity
NOTICE
This event is issued when a group quota has been exceeded on a tree. This event will not be repeated for this group and tree for a set time or until a 'quota resize' is performed. The amount of time is set by the 'quota logmsg' command.
Corrective Action
Reduce usage by members of this group in this tree or increase the quota and run 'quota resize'.
Syslog Message
gid %d tid %d: disk quota exceeded on volume %s%s%s%s. Additional warnings will be suppressed for approximately %d minutes or until a 'quota resize' is performed.
tid (INT): The tree identifier
wafl.quota.names.createFail
Severity
NOTICE
This message occurs when the system cannot create the quota names file.
Corrective Action
(None).
Syslog Message
quota: Could not create new quota names file on %s %s%s%s%s.
wafl.quota.ntfs.defaultAclFail
Severity
NOTICE
This message indicates that the system was unable to set the default ACL on an NTFS volume.
Corrective Action
Set the security style to NTFS again or re-create the volume.
Syslog Message
Unable to set default ACL on NTFS %s %s%s%s%s.
type (STRING): Type of object (volume/aggregate).
volident (STRING): Unique identifier of the volume when the volume name by itself is insufficient.
wafl.quota.off.vol.fail
Severity
ERROR
This message occurs when the system could not turn off quotas on the volume.
Corrective Action
Use the 'quota off' command to turn off quotas on the volume.
Syslog Message
Quotas could not be turned off on volume %s%s.
owner (STRING): Owner of the volume
vol (STRING): Name of the volume
wafl.quota.qtree.correct
Severity
NOTICE
This message occurs when a tree quota has been corrected.
Corrective Action
(None).
Syslog Message
(None).
wafl.quota.qtree.exceeded
Severity
NOTICE
This event is issued when a tree quota has been exceeded on a volume. This event will not be repeated for this tree for a set amount of time or until a 'quota resize' is performed. The amount of time is set by the 'quota logmsg' command.
Corrective Action
Reduce usage in this tree or increase the quota and run 'quota resize'.
Syslog Message
tid %d: tree quota exceeded on %s %s%s%s%s. Additional warnings will be suppressed for approximately %d minutes or until a 'quota resize' is performed.
mins (INT): Number of minutes warnings will be suppressed
object_uuid (STRING): Volume instance UUID of the resource object.
wafl.quota.sec.change
Severity
INFORMATIONAL
This message indicates that the security style for a directory has been changed.
Corrective Action
(None).
Syslog Message
security style for /vol/%s%s%s/%s changed from %s to %s
dir (STRING): Directory name.
ostyle (STRING): Former security style.
nstyle (STRING): New security style.
wafl.quota.user.exceeded
Severity
NOTICE
This event is issued when a user quota has been exceeded on a volume. This event will not be repeated for this user and volume for a set time or until a 'quota resize' is performed. The amount of time is set by the 'quota logmsg' command.
Corrective Action
Reduce usage by this user on this volume or increase the quota and run 'quota resize'.
Syslog Message
uid %d: disk quota exceeded on volume %s%s%s%s. Additional warnings will be suppressed for approximately %d minutes or until a 'quota resize' is performed.
id (INT): The user identifier
wafl.quota.user.exceeded.win
Severity
NOTICE
Corrective Action
Syslog Message
disk quota exceeded on volume %s%s%s%s for Windows user ID: %s. Additional warnings will be suppressed for approximately %d minutes or until a 'quota resize' is performed.
id (STRING): Windows user identifier
wafl.quota.userQtree.correct
Severity
NOTICE
This message occurs when a user quota has been corrected.
Corrective Action
(None).
Syslog Message
(None).
id (INT): User identifier.
wafl.quota.userQtree.correct.win
Severity
NOTICE
This message occurs when a user quota has been corrected and the user ID is a SID.
Corrective Action
(None).
Syslog Message
(None).
id (STRING): Windows identifier value.
wafl.quota.userQtree.exceeded
Severity
NOTICE
This event is issued when a user quota has been exceeded on a tree. This event will not be repeated for this user and tree for a set time or until a 'quota resize' is performed. The amount of time is set by the 'quota logmsg' command.
Corrective Action
Reduce usage by this user in this tree or increase the quota and run 'quota resize'.
Syslog Message
uid %d tid %d: disk quota exceeded on volume %s%s%s%s. Additional warnings will be suppressed for approximately %d minutes or until a 'quota resize' is performed.
wafl.quota.userQtree.exceeded.win
Severity
NOTICE
Corrective Action
Syslog Message
tid %d: disk quota exceeded on volume %s%s%s%s for Windows user ID: %s. Additional warnings will be suppressed for approximately %d minutes or until a 'quota resize' is performed.
