wafl.seclabel events
Creating your file...
wafl.seclabel.syncsm.mutex
- Severity
NOTICE
- Description
This message occurs when the mutual exclusion has failed between the SnapMirror Synchronous and NFS v4.2 Security Labels features. This happens when an existing volume participating in a SnapMirror relationship receives an NFS "open", "create", or "setattr" operation carrying a security label. The system will not let a security label operation continue on a volume that participates in a SnapMirror Synchronous relationship, so the system administrator must either stop mirroring the volume or drop the security label operation completely.
- Corrective Action
(None).
- Syslog Message
An incompatible NFS v4.2 security label operation was received on a file in volume "%s" having a SnapMirror Synchronous relationship. To allow NFS operations carrying security label on the volume, the mirroring must be stopped first: FSID "%d" SNAPID "%d" FILEID "%llu": "%s"
- Parameters
volname (STRING): Volume name.
fsid (INT): File System ID (FSID) of the volume.
snapid (INT): Snapshot copy ID.
fileid (LONGINT): File ID.
error_msg (STRING): Detailed error message to provide context while debugging the issue. The relevant input/output parameters of the message are also included to aid in debugging.
