wafl.vv events
Creating your file...
wafl.vv.bad.DSIDorMSID
- Severity
ERROR
- Description
This message occurs when Data ONTAP® cannot map a volume to serve a client request because of invalid data Set Identifiers. Protocol access to the volume is disabled.
- Corrective Action
Take the volume offline and contact NetApp technical support.
- Syslog Message
Cannot map volume '%s%s%s' to serve client requests because of invalid data set identifiers.
- Parameters
vol (STRING): Volume name
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
wafl.vv.clone.splitBusySnap
- Severity
NOTICE
- Description
This event is to inform the user that a volume clone cannot split from its parent volume due to busy snapshots.
- Corrective Action
Determine which snapshots in the clone volume are busy and correct the condition that is causing them to be busy. Then, retry the operation.
- Syslog Message
Volume '%s%s%s' has locked snapshots, not splitting.
- Parameters
vol (STRING): The volume name
wafl.vv.clone.splitNoScan
- Severity
NOTICE
- Description
This event is to inform user that the system is unable to start a volume clone scanner, so the clone volume will not be split from its parent volume.
- Corrective Action
This may be a temporary issue. Please retry the volume clone split operation after sometime.
- Syslog Message
Unable to start clone split scanner on volume '%s%s%s'.
- Parameters
wafl.vv.dup.DSID2
- Severity
ERROR
- Description
This message occurs when another volume is already registered with the data set identifier (DSID) assigned to this volume.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
Duplicate volume '%s%s%s' DSID (%08x) detected in aggregate '%s'.
- Parameters
vol (STRING): Volume name.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
dsid (LONGINT): Data set identifier.
aggr (STRING): Aggregate name.
wafl.vv.dup.UUID
- Severity
NOTICE
- Description
This message occurs when the system detects and updates a duplicate volume Universally Unique Identifier (UUID).
- Corrective Action
(None).
- Syslog Message
vvol '%s' in aggregate '%s' duplicate UUID %s was changed to %s.
- Parameters
old_uuid (STRING): Old duplicated UUID for the volume.
new_uuid (STRING): Replacement UUID for the volume.
wafl.vv.raidfile.open
- Severity
NOTICE
- Description
This event is to inform user that the system can not open the raid label file for update and the reason.
- Corrective Action
(None).
- Syslog Message
Unable to open volume descriptor: %s
- Parameters
err (STRING): The error message
wafl.vv.raidfile.readOnly
- Severity
NOTICE
- Description
This event is to inform user that the raid label file can not be updated on a read only volume.
- Corrective Action
(None).
- Syslog Message
Unable to update volume descriptor, aggregate '%s' is readonly
- Parameters
wafl.vv.raidfile.update
- Severity
NOTICE
- Description
This event is to inform user that while renaming a virtual volume, the system is unable to update the volume's raid label file
- Corrective Action
(None).
- Syslog Message
%s: Can't rewrite descriptor for volume '%s%s%s', aggregate '%s', error code %d.
- Parameters
cmd (STRING): The command name
aggr (STRING): The aggregate name
err (INT): The error code
wafl.vv.regen.instance.uuid
- Severity
INFORMATIONAL
- Description
This message occurs when the instance UUID and the provenance UUID of a FlexVol(tm) volume have been regenerated.
- Corrective Action
(None).
- Syslog Message
For FlexVol volume '%s' with FSID 0x%x and instance UUID %s, a new instance UUID and provenance UUID (both being %s) have been generated.
- Parameters
fsid (INT): File system identifier.
oldinstuuid (STRING): Old instance UUID of the volume.
instuuid (STRING): New instance UUID of the volume. This is also the new prevenance UUID.
wafl.vv.rename.dup
- Severity
NOTICE
- Description
This message occurs when a duplicate flexible volume name is changed to a unique name.
- Corrective Action
(None).
- Syslog Message
Duplicate flexible volume name '%s%s%s' changed to '%s%s%s' in aggregate '%s'.
- Parameters
oldname (STRING): Duplicate name.
volident1 (STRING): If the volume belongs to a vserver, this is that vserver's Universal Unique Identifier (UUID).
newname (STRING): New name.
app2 (STRING): Application UUID.
volident2 (STRING): If the volume belongs to a vserver, this is that vserver's Universal Unique Identifier (UUID).
aggrname (STRING): Name of the containing aggregate.
wafl.vv.set.size
- Severity
NOTICE
- Description
This event is issued when setting virtual volume size to the size indicated in fsinfo
- Corrective Action
(None).
- Syslog Message
Setting volume size for %s%s%s%s to match nominal size.
- Parameters
owner (STRING): The volume owner
name (STRING): The volume name
wafl.vv.softlocks.noParent
- Severity
NOTICE
- Description
This event is to inform user that to remove softlocks associated with a volume clone, the parent volume must be online
- Corrective Action
(None).
- Syslog Message
Unable to find parent volume when destroying clone '%s%s%s' softlocks. Ensure the parent volume is online then retry the operation.
- Parameters
wafl.vv.vol.config
- Severity
NOTICE
- Description
This event is issued to inform the user that the system can not configure a virtual volume and the reason.
- Corrective Action
(None).
- Syslog Message
Unable to configure volume in aggregate '%s': %s
- Parameters
err (STRING): The error string
wafl.vv.vol.maxvols
- Severity
NOTICE
- Description
This message occurs when the system cannot configure a FlexVol® volume because the maximum number of volumes has been reached.
- Corrective Action
Destroy some existing volumes to make room for new ones.
- Syslog Message
Cannot configure FlexVol volume '%s' (UUID %s) in aggregate '%s': There are too many FlexVol volumes (%d) on the system. The limit for %s is %d.
- Parameters
vol (STRING): FlexVol name.
uuid (STRING): FlexVol unique ID.
aggregate (STRING): Aggregate name.
count (INT): Current number of FlexVol volumes.
model (STRING): System model name.
limit (INT): Limit for the number of FlexVol volumes.
