ONTAP EMS reference
wafl.vv events
wafl.vv.bad.DSIDorMSID
Severity
ERROR
This message occurs when Data ONTAP® cannot map a volume to serve a client request because of invalid data Set Identifiers. Protocol access to the volume is disabled.
Corrective Action
Take the volume offline and contact NetApp technical support.
Syslog Message
Cannot map volume '%s%s%s' to serve client requests because of invalid data set identifiers.
vol (STRING): Volume name
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
wafl.vv.clone.splitBusySnap
Severity
NOTICE
This event is to inform the user that a volume clone cannot split from its parent volume due to busy snapshots.
Corrective Action
Determine which snapshots in the clone volume are busy and correct the condition that is causing them to be busy. Then, retry the operation.
Syslog Message
Volume '%s%s%s' has locked snapshots, not splitting.
vol (STRING): The volume name
wafl.vv.clone.splitNoScan
Severity
NOTICE
This event is to inform user that the system is unable to start a volume clone scanner, so the clone volume will not be split from its parent volume.
Corrective Action
This may be a temporary issue. Please retry the volume clone split operation after sometime.
Syslog Message
Unable to start clone split scanner on volume '%s%s%s'.
wafl.vv.dup.DSID2
Severity
ERROR
This message occurs when another volume is already registered with the data set identifier (DSID) assigned to this volume.
Corrective Action
Contact NetApp technical support.
Syslog Message
Duplicate volume '%s%s%s' DSID (%08x) detected in aggregate '%s'.
vol (STRING): Volume name.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
dsid (LONGINT): Data set identifier.
aggr (STRING): Aggregate name.
wafl.vv.dup.UUID
Severity
NOTICE
This message occurs when the system detects and updates a duplicate volume Universally Unique Identifier (UUID).
Corrective Action
(None).
Syslog Message
vvol '%s' in aggregate '%s' duplicate UUID %s was changed to %s.
old_uuid (STRING): Old duplicated UUID for the volume.
new_uuid (STRING): Replacement UUID for the volume.
wafl.vv.raidfile.open
Severity
NOTICE
This event is to inform user that the system can not open the raid label file for update and the reason.
Corrective Action
(None).
Syslog Message
Unable to open volume descriptor: %s
err (STRING): The error message
wafl.vv.raidfile.readOnly
Severity
NOTICE
This event is to inform user that the raid label file can not be updated on a read only volume.
Corrective Action
(None).
Syslog Message
Unable to update volume descriptor, aggregate '%s' is readonly
wafl.vv.raidfile.update
Severity
NOTICE
This event is to inform user that while renaming a virtual volume, the system is unable to update the volume's raid label file
Corrective Action
(None).
Syslog Message
%s: Can't rewrite descriptor for volume '%s%s%s', aggregate '%s', error code %d.
cmd (STRING): The command name
aggr (STRING): The aggregate name
err (INT): The error code
wafl.vv.regen.instance.uuid
Severity
INFORMATIONAL
This message occurs when the instance UUID and the provenance UUID of a FlexVol(tm) volume have been regenerated.
Corrective Action
(None).
Syslog Message
For FlexVol volume '%s' with FSID 0x%x and instance UUID %s, a new instance UUID and provenance UUID (both being %s) have been generated.
fsid (INT): File system identifier.
oldinstuuid (STRING): Old instance UUID of the volume.
instuuid (STRING): New instance UUID of the volume. This is also the new prevenance UUID.
wafl.vv.rename.dup
Severity
NOTICE
This message occurs when a duplicate flexible volume name is changed to a unique name.
Corrective Action
(None).
Syslog Message
Duplicate flexible volume name '%s%s%s' changed to '%s%s%s' in aggregate '%s'.
oldname (STRING): Duplicate name.
volident1 (STRING): If the volume belongs to a vserver, this is that vserver's Universal Unique Identifier (UUID).
newname (STRING): New name.
app2 (STRING): Application UUID.
volident2 (STRING): If the volume belongs to a vserver, this is that vserver's Universal Unique Identifier (UUID).
aggrname (STRING): Name of the containing aggregate.
wafl.vv.set.size
Severity
NOTICE
This event is issued when setting virtual volume size to the size indicated in fsinfo
Corrective Action
(None).
Syslog Message
Setting volume size for %s%s%s%s to match nominal size.
owner (STRING): The volume owner
name (STRING): The volume name
wafl.vv.softlocks.noParent
Severity
NOTICE
This event is to inform user that to remove softlocks associated with a volume clone, the parent volume must be online
Corrective Action
(None).
Syslog Message
Unable to find parent volume when destroying clone '%s%s%s' softlocks. Ensure the parent volume is online then retry the operation.
wafl.vv.vol.config
Severity
NOTICE
This event is issued to inform the user that the system can not configure a virtual volume and the reason.
Corrective Action
(None).
Syslog Message
Unable to configure volume in aggregate '%s': %s
err (STRING): The error string
wafl.vv.vol.maxvols
Severity
NOTICE
This message occurs when the system cannot configure a FlexVol® volume because the maximum number of volumes has been reached.
Corrective Action
Destroy some existing volumes to make room for new ones.
Syslog Message
Cannot configure FlexVol volume '%s' (UUID %s) in aggregate '%s': There are too many FlexVol volumes (%d) on the system. The limit for %s is %d.
vol (STRING): FlexVol name.
uuid (STRING): FlexVol unique ID.
aggregate (STRING): Aggregate name.
count (INT): Current number of FlexVol volumes.
model (STRING): System model name.
limit (INT): Limit for the number of FlexVol volumes.
