ONTAP EMS reference
air.repair events
air.repair EMS events occur when there is an inconsistency in the persistent lock entry metafile.
air.repair.prsist.lock.entry
Severity
NOTICE
This message occurs when there is an inconsistency in the persistent lock entry metafile. The inconsistent entry is repaired upon detection if there is a corresponding in-core record.
Corrective Action
(None).
Syslog Message
Persistent lock entry %s certification failed: Condition: %s, source: %s, state: %s.
entry (STRING): Lock entry type and origin file ID pair describing the entry.
condition (STRING): Initial validation test that fails.
source (STRING): Location of the failing metadata validation test.
state (STRING): Description of the remote lock entry metafile metadata state that is found to be inconsistent.
