air.repair events
air.repair EMS events occur when there is an inconsistency in the persistent lock entry metafile.
air.repair.prsist.lock.entry
- Severity
NOTICE
- Description
This message occurs when there is an inconsistency in the persistent lock entry metafile. The inconsistent entry is repaired upon detection if there is a corresponding in-core record.
- Corrective Action
(None).
- Syslog Message
Persistent lock entry %s certification failed: Condition: %s, source: %s, state: %s.
- Parameters
entry (STRING): Lock entry type and origin file ID pair describing the entry.
condition (STRING): Initial validation test that fails.
source (STRING): Location of the failing metadata validation test.
state (STRING): Description of the remote lock entry metafile metadata state that is found to be inconsistent.
