asup.aods events
asup.aods.response.overLimit
Severity
ERROR
This message occurs when the size of the response from the AutoSupport OnDemand Server (AODS) goes over the AOD response buffer size limit in ONTAP.
Corrective Action
Contact Contact NetApp technical support. for assistance.
Syslog Message
AutoSupport OnDemand Server (AODS) response went over the response buffer size limit in ONTAP. Size limit: %u bytes.
SizeLimit (INT): AOD response buffer size limit in bytes.
asup.aods.response.timeOut
Severity
ERROR
This message occurs when a response is not received from the AutoSupport OnDemand Server (AODS) before the system time limit.
Corrective Action
Check AOD Server connectivity using the "autosupport check show-details -check-type ondemand-server" command. If the issue persists, contact NetApp technical support.
Syslog Message
AutoSupport OnDemand Server (AODS) response was not received before the %u second time limit.
TimeLimit (INT): System AODS response time limit in seconds.
