asup.aods events
asup.aods.response.overLimit
- Severity
ERROR
 - Description
This message occurs when the size of the response from the AutoSupport OnDemand Server (AODS) goes over the AOD response buffer size limit in ONTAP.
 - Corrective Action
Contact Contact NetApp technical support. for assistance.
 - Syslog Message
AutoSupport OnDemand Server (AODS) response went over the response buffer size limit in ONTAP. Size limit: %u bytes.
 - Parameters
SizeLimit (INT): AOD response buffer size limit in bytes.
asup.aods.response.timeOut
- Severity
ERROR
 - Description
This message occurs when a response is not received from the AutoSupport OnDemand Server (AODS) before the system time limit.
 - Corrective Action
Check AOD Server connectivity using the "autosupport check show-details -check-type ondemand-server" command. If the issue persists, contact NetApp technical support.
 - Syslog Message
AutoSupport OnDemand Server (AODS) response was not received before the %u second time limit.
 - Parameters
TimeLimit (INT): System AODS response time limit in seconds.
