ONTAP EMS reference
callhome.nvram events
callhome.nvram EMS events occur when ONTAP encounters issues associated with NVRAM hardware.
callhome.nvram.cecc
Severity
ERROR
This message occurs when excessive correctable error-correcting code (ECC) memory errors are reported by the NVRAM complex. If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
Corrective Action
Use the "system environment sensors show -hidden true" cluster shell command to view the current "NV Correctable ECC count" and "NV Correctable ECC rate" values. Contact NetApp technical support for further assistance.
Syslog Message
Call home for %s.
subject (STRING): AutoSupport subject or title for this event.
callhome.nvram.failure
Severity
EMERGENCY
This message occurs when the NVRAM card has experienced a critical hardware failure. The system will shut down to avoid potential data loss. If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
Corrective Action
Contact NetApp technical support to replace the NVRAM card.
Syslog Message
Call home for NVRAM FAILURE
callhome.nvram.iofs.fail
Severity
ERROR
This message occurs in a FireStorm instance when a read or write to its nonvolatile memory (NVRAM) device fails. The instance will panic. If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
Corrective Action
Restart the FireStorm instance. If the issue persists, contact NetApp technical support.
Syslog Message
Call home for NVRAM failure at %s, I/O type %s.
io_type (STRING): Type of failed operation (read or write).
tag (STRING): Supplemental event identifier.
error (LONGINT): I/O error code.
callhome.nvram.openfs.fail
Severity
ERROR
This message occurs when a FireStorm instance is unable to open its nonvolatile memory (NVRAM) device. The instance will panic.
Corrective Action
Restart the instance. If the issue persists, contact NetApp technical support.
Syslog Message
Call home for open failure at %s on NVRAM file %s, error %d.
nvram_backing (STRING): Name of the NVRAM backing file.
fileio_error (LONGINT): Open error code.
callhome.nvram.parityErr
Severity
ERROR
This message occurs when excessive internal parity errors are reported by the NVRAM complex. If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
Corrective Action
Use the "system environment sensors show -hidden true" command to view the current "NVRAM12 Parity Count" and "NVRAM12 Parity Delta" values. Your system is at risk of data loss in the event of a power failure. Contact NetApp technical support to assist with possible hardware replacement of the NVRAM module.
Syslog Message
Call home for %s.
