ONTAP EMS reference
cf.misc events
cf.misc EMS events occur when ONTAP encounters issues associated with miscellaneous high-availability operations.
cf.misc.givebackPartnerNotReady
Severity
NOTICE
The message occurs when a giveback is initiated before the partner has reached waiting-for-giveback state.
Corrective Action
(None).
Syslog Message
Giveback is being initiated before the partner is in the waiting-for-giveback state. The partner is in the %s state.
state (STRING): Current state of the partner.
cf.misc.icNicFailureTakeover
Severity
ALERT
This message occurs when a takeover is initiated because InterConnect NIC failed on the partner node.
Corrective Action
Replace the network interface card of InterConnect which went down on the partner node.
Syslog Message
Failover monitor: takeover initiated because of InterConnect NIC failure on the partner node.
(None).
cf.misc.operatorDisable
Severity
ERROR
This message occurs when the operator disables the high-availability (HA) pair.
Corrective Action
Use the "storage failover modify -enabled true" command to reenable failover.
Syslog Message
Failover monitor: operator initiated disabling of takeover.
(None).
cf.misc.operatorDisableOption
Severity
ERROR
This event is issued when the operator disables a High Availability (HA) option.
Corrective Action
Re-enable the option
Syslog Message
(None).
option (STRING): Name of the option
cf.misc.operatorEnable
Severity
NOTICE
This event is issued when the operator enables failover between the 2 nodes.
Corrective Action
(None).
Syslog Message
Failover monitor: operator initiated enabling of failover.
(None).
cf.misc.operatorEnableOption
Severity
NOTICE
This event is issued when the operator enables a controller failover option.
Corrective Action
(None).
Syslog Message
(None).
cf.misc.operatorForcedTakeover
Severity
NOTICE
This event is issued when a forced takeover is initiated by the operator.
Corrective Action
(None).
Syslog Message
Failover monitor: forced takeover initiated by operator
(None).
cf.misc.operatorGiveback
Severity
INFORMATIONAL
This event is issued when a giveback is initiated by the operator.
Corrective Action
(None).
Syslog Message
Failover monitor: %s initiated by operator
strengthString (STRING): External string
strengthCode (INT): Internal code for strength
cf.misc.operatorTakeover
Severity
NOTICE
This event is issued when a takeover is initiated by the operator.
Corrective Action
(None).
Syslog Message
Failover monitor: takeover initiated by operator
(None).
cf.misc.ProgTakeover
Severity
NOTICE
This message is issued when a takeover is initiated programmatically by Data ONTAP®.
Corrective Action
(None).
Syslog Message
Failover monitor: takeover initiated.
(None).
cf.misc.ProgTakeoverFail
Severity
NOTICE
This message occurs when a takeover is initiated programmatically by Data ONTAP® and the takeover request fails.
Corrective Action
Check the reason string and repair the problem reported.
Syslog Message
Failover monitor: Programmatic takeover failed (%s)
errorstr (STRING): Error string returned by the failover monitor.
cf.misc.ProgTakeoverFailInit
Severity
NOTICE
This message occurs when a takeover is initiated programmatically by Data ONTAP® and the takeover request fails because the controller is set to "non_ha" mode or is not initialized.
Corrective Action
Set the HA mode to "ha" by using the "storage failover modify -mode ha" command, and then reboot the node.
Syslog Message
Failover monitor: Programmatic takeover failed due to initialization issues.
(None).
cf.misc.ProgTakeoverFailInTO
Severity
NOTICE
This message occurs when a takeover is initiated programmatically by Data ONTAP® and the node is already in takeover mode.
Corrective Action
(None).
Syslog Message
Failover monitor: Programmatic takeover failed due to previous takeover.
(None).
cf.misc.ProgTakeoverFailNotUp
Severity
NOTICE
This message occurs when a negotiated takeover is initiated programmatically by Data ONTAP® and the partner node is not up.
Corrective Action
Bring up the partner node.
Syslog Message
Failover monitor: Programmatic takeover failed because the partner node is not up.
(None).
cf.misc.ProgTakeoverFailPartnerDeny
Severity
NOTICE
This message occurs when a takeover is initiated programmatically by Data ONTAP® and the partner node denies the takeover request.
Corrective Action
Check previous EMS messages to determine why takeover was denied.
Syslog Message
Failover monitor: Programmatic takeover failed because the partner node denied the takeover request.
(None).
cf.misc.ProgTakeoverFailShutdown
Severity
NOTICE
This message occurs when a takeover is initiated programmatically by Data ONTAP® and a shutdown is in progress.
Corrective Action
Verify that both nodes are booted.
Syslog Message
Failover monitor: Programmatic takeover failed because shutdown was in progress.
(None).
