cf.misc events
cf.misc EMS events occur when ONTAP encounters issues associated with miscellaneous high-availability operations.
cf.misc.givebackPartnerNotReady
- Severity
NOTICE
- Description
The message occurs when a giveback is initiated before the partner has reached waiting-for-giveback state.
- Corrective Action
(None).
- Syslog Message
Giveback is being initiated before the partner is in the waiting-for-giveback state. The partner is in the %s state.
- Parameters
state (STRING): Current state of the partner.
cf.misc.icNicFailureTakeover
- Severity
ALERT
- Description
This message occurs when a takeover is initiated because InterConnect NIC failed on the partner node.
- Corrective Action
Replace the network interface card of InterConnect which went down on the partner node.
- Syslog Message
Failover monitor: takeover initiated because of InterConnect NIC failure on the partner node.
- Parameters
(None).
cf.misc.operatorDisable
- Severity
ERROR
- Description
This message occurs when the operator disables the high-availability (HA) pair.
- Corrective Action
Use the "storage failover modify -enabled true" command to reenable failover.
- Syslog Message
Failover monitor: operator initiated disabling of takeover.
- Parameters
(None).
cf.misc.operatorDisableOption
- Severity
ERROR
- Description
This event is issued when the operator disables a High Availability (HA) option.
- Corrective Action
Re-enable the option
- Syslog Message
(None).
- Parameters
option (STRING): Name of the option
cf.misc.operatorEnable
- Severity
NOTICE
- Description
This event is issued when the operator enables failover between the 2 nodes.
- Corrective Action
(None).
- Syslog Message
Failover monitor: operator initiated enabling of failover.
- Parameters
(None).
cf.misc.operatorEnableOption
- Severity
NOTICE
- Description
This event is issued when the operator enables a controller failover option.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
cf.misc.operatorForcedTakeover
- Severity
NOTICE
- Description
This event is issued when a forced takeover is initiated by the operator.
- Corrective Action
(None).
- Syslog Message
Failover monitor: forced takeover initiated by operator
- Parameters
(None).
cf.misc.operatorGiveback
- Severity
INFORMATIONAL
- Description
This event is issued when a giveback is initiated by the operator.
- Corrective Action
(None).
- Syslog Message
Failover monitor: %s initiated by operator
- Parameters
strengthString (STRING): External string
strengthCode (INT): Internal code for strength
cf.misc.operatorTakeover
- Severity
NOTICE
- Description
This event is issued when a takeover is initiated by the operator.
- Corrective Action
(None).
- Syslog Message
Failover monitor: takeover initiated by operator
- Parameters
(None).
cf.misc.ProgTakeover
- Severity
NOTICE
- Description
This message is issued when a takeover is initiated programmatically by Data ONTAP®.
- Corrective Action
(None).
- Syslog Message
Failover monitor: takeover initiated.
- Parameters
(None).
cf.misc.ProgTakeoverFail
- Severity
NOTICE
- Description
This message occurs when a takeover is initiated programmatically by Data ONTAP® and the takeover request fails.
- Corrective Action
Check the reason string and repair the problem reported.
- Syslog Message
Failover monitor: Programmatic takeover failed (%s)
- Parameters
errorstr (STRING): Error string returned by the failover monitor.
cf.misc.ProgTakeoverFailInit
- Severity
NOTICE
- Description
This message occurs when a takeover is initiated programmatically by Data ONTAP® and the takeover request fails because the controller is set to "non_ha" mode or is not initialized.
- Corrective Action
Set the HA mode to "ha" by using the "storage failover modify -mode ha" command, and then reboot the node.
- Syslog Message
Failover monitor: Programmatic takeover failed due to initialization issues.
- Parameters
(None).
cf.misc.ProgTakeoverFailInTO
- Severity
NOTICE
- Description
This message occurs when a takeover is initiated programmatically by Data ONTAP® and the node is already in takeover mode.
- Corrective Action
(None).
- Syslog Message
Failover monitor: Programmatic takeover failed due to previous takeover.
- Parameters
(None).
cf.misc.ProgTakeoverFailNotUp
- Severity
NOTICE
- Description
This message occurs when a negotiated takeover is initiated programmatically by Data ONTAP® and the partner node is not up.
- Corrective Action
Bring up the partner node.
- Syslog Message
Failover monitor: Programmatic takeover failed because the partner node is not up.
- Parameters
(None).
cf.misc.ProgTakeoverFailPartnerDeny
- Severity
NOTICE
- Description
This message occurs when a takeover is initiated programmatically by Data ONTAP® and the partner node denies the takeover request.
- Corrective Action
Check previous EMS messages to determine why takeover was denied.
- Syslog Message
Failover monitor: Programmatic takeover failed because the partner node denied the takeover request.
- Parameters
(None).
cf.misc.ProgTakeoverFailShutdown
- Severity
NOTICE
- Description
This message occurs when a takeover is initiated programmatically by Data ONTAP® and a shutdown is in progress.
- Corrective Action
Verify that both nodes are booted.
- Syslog Message
Failover monitor: Programmatic takeover failed because shutdown was in progress.
- Parameters
(None).
