configbr.initfailed events
configbr.initFailed
- Severity
ERROR
- Description
This message occurs when when the configuration backup and restore feature cannot initialize the necessary software components.
- Corrective Action
Verify the root volume file system is available and has enough space to create a backup with the "volume show" command. If replicated database entries could not be populated, wait 5 minutes and verify that the backup schedules are listed with the (privilege: advanced) "system configuration backup settings show -instance" command. If the backup jobs could not be created, wait 5 minutes and verify that backup jobs are displayed for each schedule with the "job show" command.
- Syslog Message
Configuration backup and restore feature could not be initialized. Error: '%s'.
- Parameters
reason (STRING): Reason for the initialization failure.
