dbs.software events
dbs.software EMS events occur when Distributed Block Store (DBS) detects a software version mismatch in the cluster.
dbs.software.version.mismatch
- Severity
ALERT
- Description
This message occurs when Distributed Block Store (DBS) detects a software version mismatch in the cluster.
- Corrective Action
Bring the node out of maintenance mode. Check for cluster faults and upgrade again if the faults are cleared.
- Syslog Message
DBS has detected a software upgrade that has failed. Cluster fault node %u, node UUID %s, type %s, fault ID %u, status %u. %s
- Parameters
nodeID (INT): Node ID number of the associated node.
nodeUuid (STRING): Node UUID string of the associated node.
cfType (STRING): DBS cluster fault type of the associated object.
cfID (INT): DBS cluster fault ID number associated with the fault.
cfStatus (INT): Current status of the cluster fault. 1 = New (just reported), 2 = Existing (updated), 3 = Resolved (closed).
cfDetails (STRING): Details of the software version that did not upgrade properly.
cfExtSrc (STRING): DBS cluster fault externalSource label created by the CreateClusterFault API command and attached to the fault for testing purposes.
