ONTAP EMS reference
disk.maint events
disk.maint EMS events occur when ONTAP encounters issues associated with disk maintenance testing.
disk.maint.test.end
Severity
NOTICE
This message occurs when maintenance testing has completed.
Corrective Action
(None).
Syslog Message
Disk %s Model [%s] S/N [%s] has completed maintenance testing with status %d (0x%x,0x%x,0x%x,0x%x).
disk_name (STRING): Name of the disk.
productID (STRING): Product name of the disk.
serialno (STRING): Serial number of the disk.
status (INT): Maintenance test completion status where 0 represents successful completion of the test.
fa0 (INTHEX): Failure byte 0.
fa1 (INTHEX): Failure byte 1.
fa2 (INTHEX): Failure byte 2.
fa3 (INTHEX): Failure byte 3.
disk.maint.test.start
Severity
NOTICE
This message occurs when maintenance testing begins on a disk.
Corrective Action
(None).
Syslog Message
Disk %s Model [%s] S/N [%s] has started maintenance testing.
