disk.toomanynvmespindles events
disk.tooManyNvmeSpindles
- Severity
ALERT
- Description
This message occurs when Data ONTAP® finds more NVMe disks present on a platform than the platform actually supports. Additional disks above the support number are ignored. Correct this issue before rebooting the system.
- Corrective Action
Too many NVMe disks have been installed. Reconfigure the system to the maximum number of NVMe disks supported.
- Syslog Message
Reached the maximum number of NVMe disks that are supported on this system of %d NVMe disks. All additional NVMe disks will be ignored. This problem must be resolved before the system is rebooted.
- Parameters
maxSpindle (INT): Maximum number of NVMe disks supported on this platform.
