ONTAP EMS reference
disk.toomanynvmespindles events
disk.toomanynvmespindles EMS events occur when Data ONTAP® finds more NVMe disks present on a platform than the platform actually supports.
disk.tooManyNvmeSpindles
Severity
ALERT
This message occurs when Data ONTAP® finds more NVMe disks present on a platform than the platform actually supports. Additional disks above the support number are ignored. Correct this issue before rebooting the system.
Corrective Action
Too many NVMe disks have been installed. Reconfigure the system to the maximum number of NVMe disks supported.
Syslog Message
Reached the maximum number of NVMe disks that are supported on this system of %d NVMe disks. All additional NVMe disks will be ignored. This problem must be resolved before the system is rebooted.
maxSpindle (INT): Maximum number of NVMe disks supported on this platform.
