      esh.term events
esh.term.error
- Severity
ERROR
 - Description
This message occurs when there is an error related to loop termination.
 - Corrective Action
Set the termination switch to the OFF position on the ESH module that is reporting the error.
 - Syslog Message
FORCED TERMINATION ERROR: TERM switch set improperly on ESH %s on channels %s disk shelf ID %d. The disk shelf connected to the OUT port of this ESH module is inaccessible.
 - Parameters
element (STRING): ESH module designator (A is the upper module, B is the lower module).
channels (STRING): Channels that have the error if local, PARTNER for high-availability partner, UNUSED if unconnected.
shelfID (INT): Disk shelf ID (1-7) of the disk shelf reporting the error.
