ONTAP EMS reference
esh.term events
esh.term EMS events occur when there is an error related to loop termination.
esh.term.error
Severity
ERROR
This message occurs when there is an error related to loop termination.
Corrective Action
Set the termination switch to the OFF position on the ESH module that is reporting the error.
Syslog Message
FORCED TERMINATION ERROR: TERM switch set improperly on ESH %s on channels %s disk shelf ID %d. The disk shelf connected to the OUT port of this ESH module is inaccessible.
element (STRING): ESH module designator (A is the upper module, B is the lower module).
channels (STRING): Channels that have the error if local, PARTNER for high-availability partner, UNUSED if unconnected.
shelfID (INT): Disk shelf ID (1-7) of the disk shelf reporting the error.
