      fpolicy.unsupportedpathlen events
fpolicy.unsupportedPathLen
- Severity
NOTICE
 - Description
This message occurs when an FPolicy screen request has a path name longer than 4k bytes. The associated file operation will not be screened by FPolicy.
 - Corrective Action
If possible remove the volume generating long path notification from FPolicy screening.
 - Syslog Message
FPolicy notification has path names with unsupported length of "%lld". Max supported path length is %lld. The associated file operation will not be screened by FPolicy.
 - Parameters
currentPathLen (LONGINT): Length of the file or directory path from root of volume.
allowedPathLen (LONGINT): Maximum supported path length.
