ONTAP EMS reference
fpolicy.unsupportedpathlen events
fpolicy.unsupportedpathlen EMS events occur when an FPolicy screen request has a path name longer than 4k bytes.
fpolicy.unsupportedPathLen
Severity
NOTICE
This message occurs when an FPolicy screen request has a path name longer than 4k bytes. The associated file operation will not be screened by FPolicy.
Corrective Action
If possible remove the volume generating long path notification from FPolicy screening.
Syslog Message
FPolicy notification has path names with unsupported length of "%lld". Max supported path length is %lld. The associated file operation will not be screened by FPolicy.
currentPathLen (LONGINT): Length of the file or directory path from root of volume.
allowedPathLen (LONGINT): Maximum supported path length.
