gpo.sec events
gpo.sec.EvtAdt.applied
Severity
INFORMATIONAL
This message occurs when applying group policy object (GPO) event audit policy settings succeeds.
Corrective Action
(None).
Syslog Message
Successfully applied event audit and log settings to Vserver %s.
vserver (STRING): Vserver name.
gpo.sec.EvtAdt.notApplied
Severity
ERROR
This message occurs when applying group policy object (GPO) event audit policy settings fails.
Corrective Action
Address the specific reason for the issue, and then apply the settings again by entering the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
Syslog Message
Failed to apply event audit and log settings to Vserver %s, reason: %s.
reason (STRING): Reason for the failure.
gpo.sec.fsec.applied
Severity
INFORMATIONAL
This message occurs when the group policy object (GPO) file security settings are applied.
Corrective Action
(None).
Syslog Message
Successfully applied file security settings to Vserver %s.
gpo.sec.fsec.notApplied
Severity
ERROR
This message occurs when applying group policy object (GPO) file security setings fails.
Corrective Action
Syslog Message
Failed to apply file security settings to Vserver %s, reason: %s.
gpo.sec.fsec.notAppliedFor
Severity
NOTICE
This message occurs when applying a group policy object (GPO) security descriptor to a given file fails.
Corrective Action
Syslog Message
Failed to apply file security settings to path %s in Vserver %s, reason: %s.
path (STRING): File and directory path to which a security descriptor is to be applied.
gpo.sec.kerb.applied
Severity
INFORMATIONAL
This message occurs when applying group policy object (GPO) Kerberos settings succeeds.
Corrective Action
(None).
Syslog Message
Successfully applied Kerberos settings to Vserver %s.
gpo.sec.kerb.notApplied
Severity
ERROR
This message occurs when applying group policy object (GPO) Kerberos settings fails.
Corrective Action
Syslog Message
Failed to apply Kerberos settings to Vserver %s, reason: %s.
gpo.sec.privR.applied
Severity
INFORMATIONAL
This message occurs when applying group policy object (GPO) privilege-rights settings succeeds.
Corrective Action
(None).
Syslog Message
Successfully applied privilege rights settings to Vserver %s.
gpo.sec.privR.notApplied
Severity
ERROR
This message occurs when applying group policy object (GPO) privilege-rights settings fails.
Corrective Action
Syslog Message
Failed to apply privilege-rights settings to Vserver %s, reason: %s.
gpo.sec.privR.notAppliedFor
Severity
NOTICE
This message occurs when applying group policy object (GPO) privilege-rights fails for a supported setting.
Corrective Action
Syslog Message
Failed to apply privilege-rights %s setting to Vserver %s, reason: %s.
setting (STRING): Name of the setting: Take ownership, Security privilege, or Bypass traverse.
gpo.sec.reg.applied
Severity
INFORMATIONAL
This message occurs when applying group policy object (GPO) security registry settings succeeds.
Corrective Action
(None).
Syslog Message
Successfully applied security registry settings to Vserver %s.
gpo.sec.reg.notAppliedFor
Severity
ERROR
This message occurs when applying a group policy object (GPO) security registry setting fails.
Corrective Action
Syslog Message
Failed to apply security registry %s setting to Vserver %s, reason: %s.
setting (STRING): Name of the setting: SMB signing.
gpo.sec.resAno.applied
Severity
INFORMATIONAL
This message occurs when applying group policy object (GPO) security restrict anonymous settings succeeds.
Corrective Action
(None).
Syslog Message
Successfully applied restrict anonymous settings to Vserver %s.
gpo.sec.resAno.notApplied
Severity
ERROR
This message occurs when applying group policy object (GPO) security restrict anonymous settings fails.
Corrective Action
Syslog Message
Failed to apply restrict anonymous settings to Vserver %s, reason: %s.
gpo.sec.resGrp.applied
Severity
INFORMATIONAL
This message occurs when applying group policy object (GPO) restricted-groups settings succeeds.
Corrective Action
(None).
Syslog Message
Successfully applied restricted group settings to Vserver %s.
gpo.sec.resGrp.notApplied
Severity
ERROR
This message occurs when applying group policy object (GPO) restricted-groups settings fails.
Corrective Action
Syslog Message
Failed to apply restricted-groups settings to Vserver %s, reason: %s.
gpo.sec.resGrp.notAppliedFor
Severity
NOTICE
This message occurs when applying group policy object (GPO) restricted-groups settings fails for a given group.
Corrective Action
Syslog Message
Failed to apply restricted-groups settings for group %s in Vserver %s, reason: %s.
group (STRING): Group name.
