gpo.sec events
gpo.sec EMS events occur when ONTAP encounters issues associated with Group Policy Object (GPO) security policy settings.
gpo.sec.EvtAdt.applied
- Severity
INFORMATIONAL
- Description
This message occurs when applying group policy object (GPO) event audit policy settings succeeds.
- Corrective Action
(None).
- Syslog Message
Successfully applied event audit and log settings to Vserver %s.
- Parameters
vserver (STRING): Vserver name.
gpo.sec.EvtAdt.notApplied
- Severity
ERROR
- Description
This message occurs when applying group policy object (GPO) event audit policy settings fails.
- Corrective Action
Check the CIFS configuration by running the "vserver cifs show -vserver <vserver-name>" and "vserver cifs check -vserver <vserver-name>" commands. Run the job again using the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
- Syslog Message
Failed to apply event audit and log settings to Vserver %s, reason: %s.
- Parameters
reason (STRING): Reason for the failure.
gpo.sec.fsec.applied
- Severity
INFORMATIONAL
- Description
This message occurs when the group policy object (GPO) file security settings are applied.
- Corrective Action
(None).
- Syslog Message
Successfully applied file security settings to Vserver %s.
- Parameters
gpo.sec.fsec.notApplied
- Severity
ERROR
- Description
This message occurs when applying group policy object (GPO) file security setings fails.
- Corrective Action
- Syslog Message
Failed to apply file security settings to Vserver %s, reason: %s.
- Parameters
gpo.sec.fsec.notAppliedFor
- Severity
NOTICE
- Description
This message occurs when applying a group policy object (GPO) security descriptor to a given file fails.
- Corrective Action
- Syslog Message
Failed to apply file security settings to path %s in Vserver %s, reason: %s.
- Parameters
path (STRING): File and directory path to which a security descriptor is to be applied.
gpo.sec.kerb.applied
- Severity
INFORMATIONAL
- Description
This message occurs when applying group policy object (GPO) Kerberos settings succeeds.
- Corrective Action
(None).
- Syslog Message
Successfully applied Kerberos settings to Vserver %s.
- Parameters
gpo.sec.kerb.notApplied
- Severity
ERROR
- Description
This message occurs when applying group policy object (GPO) Kerberos settings fails.
- Corrective Action
- Syslog Message
Failed to apply Kerberos settings to Vserver %s, reason: %s.
- Parameters
gpo.sec.privR.applied
- Severity
INFORMATIONAL
- Description
This message occurs when applying group policy object (GPO) privilege-rights settings succeeds.
- Corrective Action
(None).
- Syslog Message
Successfully applied privilege rights settings to Vserver %s.
- Parameters
gpo.sec.privR.notApplied
- Severity
ERROR
- Description
This message occurs when applying group policy object (GPO) privilege-rights settings fails.
- Corrective Action
- Syslog Message
Failed to apply privilege-rights settings to Vserver %s, reason: %s.
- Parameters
gpo.sec.privR.notAppliedFor
- Severity
NOTICE
- Description
This message occurs when applying group policy object (GPO) privilege-rights fails for a supported setting.
- Corrective Action
- Syslog Message
Failed to apply privilege-rights %s setting to Vserver %s, reason: %s.
- Parameters
setting (STRING): Name of the setting: Take ownership, Security privilege, or Bypass traverse.
gpo.sec.reg.applied
- Severity
INFORMATIONAL
- Description
This message occurs when applying group policy object (GPO) security registry settings succeeds.
- Corrective Action
(None).
- Syslog Message
Successfully applied security registry settings to Vserver %s.
- Parameters
gpo.sec.reg.notAppliedFor
- Severity
ERROR
- Description
This message occurs when applying a group policy object (GPO) security registry setting fails.
- Corrective Action
- Syslog Message
Failed to apply security registry %s setting to Vserver %s, reason: %s.
- Parameters
setting (STRING): Name of the setting: SMB signing.
gpo.sec.resAno.applied
- Severity
INFORMATIONAL
- Description
This message occurs when applying group policy object (GPO) security restrict anonymous settings succeeds.
- Corrective Action
(None).
- Syslog Message
Successfully applied restrict anonymous settings to Vserver %s.
- Parameters
gpo.sec.resAno.notApplied
- Severity
ERROR
- Description
This message occurs when applying group policy object (GPO) security restrict anonymous settings fails.
- Corrective Action
- Syslog Message
Failed to apply restrict anonymous settings to Vserver %s, reason: %s.
- Parameters
gpo.sec.resGrp.applied
- Severity
INFORMATIONAL
- Description
This message occurs when applying group policy object (GPO) restricted-groups settings succeeds.
- Corrective Action
(None).
- Syslog Message
Successfully applied restricted group settings to Vserver %s.
- Parameters
gpo.sec.resGrp.notApplied
- Severity
ERROR
- Description
This message occurs when applying group policy object (GPO) restricted-groups settings fails.
- Corrective Action
- Syslog Message
Failed to apply restricted-groups settings to Vserver %s, reason: %s.
- Parameters
gpo.sec.resGrp.notAppliedFor
- Severity
NOTICE
- Description
This message occurs when applying group policy object (GPO) restricted-groups settings fails for a given group.
- Corrective Action
- Syslog Message
Failed to apply restricted-groups settings for group %s in Vserver %s, reason: %s.
- Parameters
group (STRING): Group name.
