nblade.ecv events
nblade.ecv.not.ready
- Severity
NOTICE
- Description
This message occurs when ONTAP® software uses a default Effective Cluster Version (ECV) before the actual ECV has been conclusively determined. Some features might not work as expected until ONTAP can select the correct ECV.
- Corrective Action
(None).
- Syslog Message
Default ECV %s has been used. The ECV value '%d' does not reflect the cluster's true ECV status.
- Parameters
ecv_variable_name (STRING): Name of the ECV value being used.
ecv_variable_value (INT): ECV value being used.
