ONTAP EMS reference
nblade.ecv events
nblade.ecv.not.ready
Severity
NOTICE
This message occurs when ONTAP® software uses a default Effective Cluster Version (ECV) before the actual ECV has been conclusively determined. Some features might not work as expected until ONTAP can select the correct ECV.
Corrective Action
(None).
Syslog Message
Default ECV %s has been used. The ECV value '%d' does not reflect the cluster's true ECV status.
ecv_variable_name (STRING): Name of the ECV value being used.
ecv_variable_value (INT): ECV value being used.
