nblade.exportaccesschkfailed events
nblade.exportaccesschkfailed EMS events occur when the network blade denies access to an exported share when a connection attempt violates an export policy.
Nblade.exportAccessChkFailed
- Severity
ERROR
- Description
This message occurs when the network blade denies access to an exported share when a connection attempt violates an export policy.
- Corrective Action
Ensure that the export policy rule for this vserver is defined properly.
- Syslog Message
(None).
- Parameters
vserverId (INT): Identifier for the vserver associated with this operation.
errorCode (INT): Error code that describes the export access check failure.
shareName (STRING): Name of the share that the user attempted to access.
