nblade.exportaccesschkfailed events
nblade.exportaccesschkfailed EMS events occur when the network blade denies access to an exported share when a connection attempt violates an export policy.
Nblade.exportAccessChkFailed
- Severity
ERROR
- Description
This message occurs when the network blade denies access to an exported share when a connection attempt violates an export policy.
- Corrective Action
Ensure that the export policy rule for this SVM is defined properly by using the "export-policy rule show" command. If necessary, add a new rule to the policy that allows access to the share using the "export-policy rule create" command.
- Syslog Message
Access denied due to a violation of an export policy. SVM ID: %d, error description: %s, share name: %s, client IP address: %s.
- Parameters
vserverId (INT): Identifier for the storage virtual machine (SVM) associated with this operation.
errorDescription (STRING): Error that describes the export access check failure.
shareName (STRING): Name of the share that the user attempted to access.
clientIp (STRING): IP address of the client.
